arlo pro view not 130
  • 1 Reply
  • 3097 Views
ASGILL
Arlo claims that arlo pro cameras have 130 deg view, that is not correct, i can bairly see outside 100 deg, also measered by plotting. i realu wanter more that 100 deg field of view for two spots. hopefully some one help or clarify this false claim.
They are wide angle cams... the older model Arlo may have been 110d, the newer are 130d.... What ever they measure out to they are fairly wide view.
It is a fixed lens and you can't change the view, tho you can move it farther back to cover more area the sense level reaches only for people to 20+ft max
