  • 2 Replies
  • 3300 Views
adriant5147
Has anyone seen the record until motion stops. function removed from the arlo pro fuction is it being removed due to a update or has it been removed for good? i recently had fedex show up and only recorded 10 seconds as before it recorded the full delivery.
There was a fix in progress with the record till motion stops... so it may have been removed till fixed.
As to the 10 seconds, that is the low end, you can go up to 2 mins.  The reset time to record is still the same
The record until motion stops feature was removed since it wasn't working. However, the removal resulted in the recording time resetting to 10 seconds. Edit your modes and rules to increase to the desired time. Don't forget to save changes.
