my Arlo pro system has been offline all day. I have rebooted router, unplugged arlo base station, and even reset everything numerous times
the base station connects and all lights are green. when I check status from app or even arlo arlo website I keep getting system disconnected messages.
I would very much like to get this thing working.
The Arlo engineering team has identified the cause and resolved this issue. Please let us know if you continue experiencing this behavior.
"Your Arlo device appears offline - Please make sure it is powered on and connected to the Internet."
THE INSULT to CONSTANTLY BLAME the Power Source or Internet,,,,,, STOP WE ARE NOT STUPID. It is again ANOTHER FLAW / DEFECT with ARLO & Netgear.
AS I Check the Power & Internet & EVERYTHING ELSE on Power & Internet are working, ARLO will slowly one camera at a time start working.
ARLO / Netgear NEEDS TO POST on their site when there are issues, it is NOT FAIR that people RELY ON SECURITY with these devices.
Can someone RECOMMEND Security Cameras that ACTUALLY WORK without THIS MANY ISSUES. I see nothing but PAGES & POSTS of COMPLAINTS.
Now my 3rd Camera is RECORDING IN RED, another chronic issue.
I'll take them. I'll even pay for shipping.
A reasonable first step is to reset the system by removing all devices in Settings, My Devices. Use the Add Device button to add the base and sync the cameras. Make sure firmware is up to date by comparing your versions to that listed in the Release Notes section here.
And you can always open a case with support.
Today, all cameras went down (I have 5) I have reset the base station, reset my router and as a test removed one camera and added it back. I get a message on all cameras: Your arlo device appears offline. Any help is appreciated.
This device is telling me that there is something wrong with the connection and power cable. I have checked, and rechecked all connections. It was reliable, but now that I have invested $500.00 after about a year it stops working properly. I can't control the cameras, the computer indicates that they are offline but they are still recording, one of them are recording upside down and I can't control that either. I thought this was a good purchase until now.
lets start with the simple one - the one thats upside down. If you go into that cam's settings is the invert image switch turned on?
mine was up for only 3 days , and now will not reconnect with base station
heru have you tried rebooting you base station and try putting new batteries in one offline cam to see if batteries died.?
I have a second base station on the exact same network that has 2 more cameras and I have no issues in the app for my second base station..
Try a browser on a computer, too - same issue? If not, sometimes force closing the app and/or logging out and back in fixes it.
Open a case with support.
So feeling nervous about this purchase after reading all through this community forum. I did get mine working again after following some tips I found on here. I did try turning base off and on twice with nothing resolving itself. But when I unplugged it from the power cord and then replugged it back in they finally came back online. Just makes me wonder though how I'm supposed to do that if I'm away on vacation and depending on these cameras to monitor my home while I'm away!
Then as for the red tone on one camera I did what one poster suggested and lightly tapped it upside down in my palm. Fixed the problem, so I'm going to assume this is a filter that goes up for night recording and isn't going back down in the day time. Ugh. I guess I'll see if it reoccurs tomorrow after it records during the night. If it's true you have to pay to return the camera and then wait for a replacement one I'm not going to be happy with that process at all!
Yep, definitely rethinking my purchase now! Again...these have only been up for FOUR days!
They like to blame the power or internet. It'd neither , it them and poor quality.
It is arlo and netgear. Enough of the dog and pony show arlo needs to, fix their product before focusing on new product, arlo is NOT CHEAP....
I don't need your b's troubleshooting, I need your company to fix your connect issues
I'm having the same problem. We just had an internet outage and I have rebooted everything too. Still says that it's not online, but I have 3 green lights. Following for answers.
Same problem here! All lights green, have restarted serveral times, but apps and website show base station is offline. Perhaps it's a problem at Netgear's end.
Having the exact same offline error. Was working fine yesterday. Tried the support number on the website but no longer in service.........
Same thing here. I'm still getting alerts and video is recording, but I cant access the live views or make adjustments to the settings.
Same problem all day today. Working fine then "offline" yet I can access my air quality monitor just fine. Get home, all light green, but no alerts no recordings, nothing. I tired all the rests, power downs, etc-still the same thing. Looking back through threads this is a common, recurring problem going back two years for which there don't seem to be any answers coming from netgear. People are turning it all off, disconnecting, resetting, etc. but this seems to keep happening. This is very frustrating.
