arlo Pro scheduling
Setup schedule Question.
I have setup a schedule to arm cameras 9m to 11:59 and 12am to 7am.
Question is what are my video settings?
How do i setup each camera?
I have viedo recording length set under "Armed". does the schedule use those video settings?
You have to just think of the Schedule as a timer.... the timer only uses the MODE you place into the time slots.
So if you are used the default mode ARMED, then yes, the record times are set in that mode ( for each camera ) are what is use.
You have two options if you want to change the record time...
1) edit the ARMED mode and change the video time for each camera
2) ( better choice ) is create a custom mode using ADD A MODE andwhen you add each camera it will allow video time record choice for each camera added
this may help; https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-create-a-mode-for-my-Arlo-Pro-Wire-Fre...
As a PS... remember when you first create a new mode it is for one camera,... SAVE it and then go back and EDIT it to add additional cameras
