Will the silicone skins from the older Arlo Wireless camera fit the new Arlo Pro camera ?
I doubt it, if it does it would not fit properly.
I had them side by side and the Pros are a little larger.
-Robert
5 REPLIES 5
-Robert
Thank you...I appreciate it...do hope they will be available somewhere sometime soon...
You're welcome Mac!
-Robert
macjohn, RobertRosal
RobertRosal's post above is correct, (the original) Arlo Pro Skins will not fit Arlo Pro. Take a look at the Arlo Pro skins here: Arlo Pro Skins - Set of 3 Black Skins (VMA4200B)
They don't seem to be available until Nov 15th from Fry's, Newegg..
