answered my own question.... It is NORMAL... the second base in settings with the red signal is just there for the alarm . It's the same base but used for an added rule in mode re siren.
Yes, only that way using the web portal, mobile app has it removed.
I was previously able to rename it to identify it as the siren but the web portal is broken so it now renames the base station instead.
