5 REPLIES 5
Uninstall and reinstall the app
Have reinstalled app. Come up with a better advice that. It still does it.
Which platform? iOS? Android? Is the audio you can hear when you pause from a Live View or from one of the recorded videos?
It is a iPhone OS. It only does it when I go live then pause the camera. The sound keeps going. Only way to stop it is turn my phone off. And it is the same camera every time.
If it's only one camera, I'd remove the camera from your device list, power cycle the base and the camera, resync the camera and see if that makes any difference
