I. looking to buy 2 white cables and adapters without buying a battery and/or charger station with them
I can't find any that are white and shorter than 20 feet. I want to use my 3 cameras indoors and plugged in with the battery installed incase I loose power in the house.
I don't need a long cable or any charger stations or extra batterys
I am afraid that if you lost power to your house, yor internet would be down unless you had it connected to UPS along with the base station, as that would go out also.
Just saying...
But I don't know of a source for the cable.
Brian
Excellent question. I only run 2 cameras on full time power so have enough adapters and cables but I can appreciate the question as if I wanted to run all cameras indoors on AC power, I wouldn't have enough. Let me do some homework
Any wire works, the only issue is, most wires are too thick on the end so, it won't plug all the way in or won't go in at all in the camera's charging port. Just cut/shave it a little bit using a knife, make it thin so it's able to plug in with no issues. That's what I did with a couple of my wires.
