Hi, Can someone please help me with where I can buy a replacement of the micro usb charging cover? I have contacted support but they can't help. I have lost the one I had on my camera and need it to protect it from the rain.
You can't buy it. I'd put a piece of waterproof tape over it, taking care to seal it fully.
Thank you for the update Jguerdat. I did found an USB end waterproof cover in Ebay and Amazon but don't know what size it is called for Alro CCTC USB port cover, do you know the size then maybe I could find it online.
No idea. You'd have to accurately measure it to see if you can find a match.
Okay many thanks jguerdat
