That's the way it's supposed to work on the Arlo Pro.
The siren is built into the base.
6 REPLIES 6
You didnt read the question properly.....yes siren suppose to work on base however siren use to come on camera also,but not anymore only comes through base and not camera.I would like for siren to come through camera, like it did before. How do I make this happen again?
siren only works through the base. that's how the system is designed.
Youre wrong.During initial installation less than a week ago, alarm when triggered would come through the camera and not the base. Thats what I d like to get back. Not sure if defective or not, but makes more sense to have choice of where alarm would sound in base or camera?
The answer provided is absolutely correct. There is no siren on a Pro camera. Only the Go camera, which doesn't use a base, has this feature. The Pro system only has a siren in the base.
yes, you definitely have a defective system which the siren was coming from the camera.
