Arlo Pro - Integration with external security systems
Good evening,
I would like to know if the system could be integrated with external security devices, like Doors/Windows sensors or similar. If it could, I would like to have some suggestions on the ones you suggest.
Thank you in advance,
Simone
I use Smartthings. The Arlo cameras trigger lights both inside and outside the house only at night time, as well as the normal notifications and recordings
