In reading literature I do see an explanation for using Arlo cameras without a base station. Further I would like to know:
1. what the base station does/provides?
2. what the mobil apps provide?
The Arlo cameras ( Arlo , Arlo PRO ) only work with a base unit... base gets hooked into router by ethernet cable.
Arlo Q cameras ( indoor rated ) hook directly in to your home wifi router
The Base sets up it's own wifi system to talk to the cameras only ( no other devices can hook in )
The mobile apps allow you to access and set the cameras, view live and record.
Does the Arlo Pro camera work with the Arlo base station?
Bennynocheese wrote:Does the Arlo Pro camera work with the Arlo base station?
Yes but you obviously don't have the Pro base station functions like the siren or USB back up recording
