Wasserstein Solar Panel Compatibility Problems
I have 3 Arlo Pro cameras, 2 using Wasserstein Solar panels and 1 using Arlo's Solar Panel. All worked fine and charged perfect until this past week when the system went offline.
After resetting both of my Wasserstein charged cameras are discharging and I am getting notices that they aren't working... If only one was the problem I would think it's a hardware issue.. but both at the same time tells me that Arlo has sabotaged my system because I didn't buy the charger from them....
Please tell me what's up Arlo?
Can't say as your using third party devices...
But, can say that the Arlo cams are VERY picky about the voltage input ( spec is tight ).. and if it doesn't fall into the proper values, it will say NFG
I understand, but why was it fine for 6 months, then now in 1 week both are not charging correctly? seems like a software change.
Or a hardware problem. Hopefully the panels didn't take out the camera port.
Same thing here.
Worked fine for months and suddenly 4 panels were not accepted by software.
Looks likes like an Arlo sabotage to fare competition from other panel manufacturers.
Very dissatisfied with Arlo.
I did test the wasserstein solar panels and they still work fine but not accepted by Arlo.
EFx,
What issues are you experiencing with your solar panels?
