  • 5 Replies
  • 9281 Views
  • 5 Likes
  • 5 In Conversation
konacam1
I have 3 Arlo Pro cameras, 2 using Wasserstein Solar panels and 1 using Arlo's Solar Panel. All worked fine and charged perfect until this past week when the system went offline.
After resetting both of my Wasserstein charged cameras are discharging and I am getting notices that they aren't working... If only one was the problem I would think it's a hardware issue.. but both at the same time tells me that Arlo has sabotaged my system because I didn't buy the charger from them....
Please tell me what's up Arlo?
5 REPLIES 5
Can't say as your using third party devices...
But, can say that the Arlo cams are VERY picky about the voltage input ( spec is tight ).. and if it doesn't fall into the proper values, it will say NFG
konacam1
I understand, but why was it fine for 6 months, then now in 1 week both are not charging correctly? seems like a software change.
Or a hardware problem. Hopefully the panels didn't take out the camera port.
EFx
Same thing here.
Worked fine for months and suddenly 4 panels were not accepted by software.
Looks likes like an Arlo sabotage to fare competition from other panel manufacturers.
Very dissatisfied with Arlo.
I did test the wasserstein solar panels and they still work fine but not accepted by Arlo.
ShayneS
EFx,
What issues are you experiencing with your solar panels?
