Want to view live on separate monitor instead of computer. Arlo came with router. Any idea?
I want live view of my 4 cameras on separate monitor not computer one. Arlo came with router. Any ideas how to do that? I need another monitor first I get it. Then I should have capability to switch monitors that's how I do it. ok need to change location of 2nd monitor... wireless here is sateiltte
You cannot gain access into the Arlo base as 1) there is no pw 2) it is not a true router.... The Arlo base only sets up a wifi network for the cameras.
As to a separate monitor, TMK, it can oly be done via an outside app/prgm... like Alexa or Homekit.
