  • 1 Reply
  • 1223 Views
pbloss
Two of our cameras are outside in positions that require ladders to take down and reset.  We would like to permanently wire power to them to keep the batteries charged.  Has anyone got a suggestion on how to do so?
Thanks very much.
You can add Arlo solar panels to each camera to greatly reduce the number of times you may need to recharge the batteries (if at all) or use the outdoor power supply to run them on AC power. Note that you'll need nearby outlets to plug these into.
