Want Outdoor cameras to have different motion detection settings to indoor
Hi,
I have 2 outdoor Cameras and 2 indoor cameras connected to a single base unit.
I currently have all 4 set to have motion detection activated and record between midnight and 06.30am so as not to be detecting family house movements all the time.
Is it possible to set both Outdoor cameras to have motion detection & record between 19.00 - 23.59 and then automatically switch to current settings of all four cameras being active - without having to switch Modes on App manually.
Seems a pretty simple SW task but the I don't see these options currently
I was an early adopter so maybe SW has improved on newer cameras but my version ( 5.0.5 (8508) )is very basic
I'm guessing you are using the new interface that uses Feed to view recordings - is that correct? Have you read this FAQ?
https://kb.arlo.com/000062777/About-Arlo-Routines-Modes-Rules-and-Automations
What you're trying to is certainly possible. After reading the above and checking out the Routines section to set up modes, rules and schedule, post back with any questions/issues. As you get started, there are options that can be set but don't bother with them yet - keep it simple.
