VMS4230 cannot activate cameras - I am following instructions
Hello. I had hoped to contact you by phone but cannot locate the phone number despite my best efforts to do so. I have followed the step-by-step instructions to activate my new VMS4230 (+ two additional cameras) and everything appears to be fine primarily because the instructions are clear and easy to comprehend. However, my numerous attempts to activate my four cameras (one by one, just inches away from the base station) have failed. The blinking blue light illuminates on all four cameras but then turns to amber before disappearing entirely. I've held on to the activation button on the camera(s) while the Sync button was blinking blue and when it wasn't yet with the same results. My PC connection is at "High Performance," fully charge and plugged in. I skimmed the trouble shooting guidelines but can't seem to crack the case. Please advise. Thank you.
When syncing, only briefly press the base sync button - don't hold it. Did that help?
