  • 1 Reply
  • 585 Views
Acjt
I  need the yellow LAN adapter for a vmd4000
Are you saying you need a replacement cable?  Or that the cable wasn't included in a new purchase?
It is just a standard ethernet patch cable - readily available at on-line sellers like Amazon, or stores like Best Buy.  Cost typically less than $10 USD.  One of many options is
Or are you are saying that the ethernet port in the base station has become detached and is lost?  That is not intended to be user-repairable, replacing the socket would require you to solder it.
