VMC4030 Every time I login to my camera I get A newer version of Adobe Flash Player is required.)
VMC4030 HW version H8 1.092.0.19-26228 Windows 10 outdoors
Have you try a different browser like Fire Fox?
What browser? Chrome and Edge will give you that banner since Flash is being deprecated and you have to enable it by clicking on the "click here" link in the banner each time you start the browser to look at Arlo. I leave the browser open all the time so I only have to do that when I reboot (I use sleep mode rather than turning the computer off when not in use).
Does it help if in Chrome you click the lock icon in the URL box and select allow in the Flash drop-in?
I will have to try that.
It worked. Thanks for that answer.
You bet. I kept seeing that annoying message too. Hopefully that solves it for both of us.
You'll have to do that every time you restart the browser. No way around it until Flash is no longer required.
Well, it is halfway through 2019. I'm surprised that the system uses Flash.
