  • 8 Replies
  • 5042 Views
iconone
VMC4030 HW version H8 1.092.0.19-26228 Windows 10 outdoors
8 REPLIES 8
Have you try a different browser like Fire Fox?
What browser? Chrome and Edge will give you that banner since Flash is being deprecated and you have to enable it by clicking on the "click here" link in the banner each time you start the browser to look at Arlo. I leave the browser open all the time so I only have to do that when I reboot (I use sleep mode rather than turning the computer off when not in use).
FrostyCan
Does it help if in Chrome you click the lock icon in the URL box and select allow in the Flash drop-in?
iconone
I will have to try that.
iconone
It worked. Thanks for that answer.
FrostyCan
You bet.  I kept seeing that annoying message too.  Hopefully that solves it for both of us.
You'll have to do that every time you restart the browser. No way around it until Flash is no longer required.
FrostyCan
Well, it is halfway through 2019.  I'm surprised that the system uses Flash.
