Hello,
As it happened few times before VMB4000r3 current ver is 1.16.6.1_3885_9330458 and not as published officially 1.16.6.1_3885_9659dd9
Please either push the correct fw or fix the publication.
Thank you
If you reboot the Base it usually will updated the Firmware. But it should have done it upon release.
Hi,
As a long time user actually as a first day user let me emphasize the problem - the fw ver is the last one and if you will check the ver history the number that I have indicated is actually not exist...So it is definitely a system glitch and it is not the first time with this system of 4000 v3.
So I am looking for other users with the same fw ver to verify it and for NG to confirm it and to find a quick fix.
Thank you
The incorrect firmware version was listed in the most recent release notes. 1.16.6.1_3885_9330458 is the current firmware version available.
Thank you for pointing out this error, i've updated the version listed in the release notes board.
