I installed an Arlo system at my home ant it is working well so far. I would like to install a separate system at my auto repair shop as well. Can you observe both systems with one account set up? Or do you have to set up a separate user name and password words?
thanks Joe
If the camera count remains at 5 or less, you can use one account. Otherwise, the second location will need to use a separate account and use Settings, Grant Access from one account to the other so all cameras appear in one login. Or upgrade your subscription.
