VMB4000 base station with arlo pro and one essential camera.
I have used the system for several years during which geofencing worked just fine. With the current software Dashboard, using the "away" setting, I expected the system to function the same as the old geofencing. It does not.
When set on "away" I get notifications and recordings on all activity all the time. I don't want this. I have not been able to determine how to set up the system to notify me only when motion happens when I am away. I would appreciate it if someone could provide the set up detail to do this.
We need to understand if you are only using "Arm Away" when you are away from home? Or are you also using it when you are home?
