VMB4000 My 1 camera will not charge
My 1 camera will not charge. The other 3 still do. How long do they last. I bought them January 2017. They are all outside protected from the sun.
The arlo pro/2 batteries are likely to be still ok, mine are still fine, purchased in 2018.
An important note is to not let them discharge below 5%, You should get a warning at 15%.
If they go lower you risk the camera locking out the charging feature to prevent damage.
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
Might be worth investigating in a spare.
YOU'RE A GENIUS!!!! Removing and replacing the battery worked on the fourth try.
It charge to 100% faster than before.
Thank you
Judyb22
