VMB4000 I Can't Add This Base Station, After I Removed It
I can't add my master profile Base station with arlo pro. Before that, everything works perfect, but today I find that no video is recorded for two days - in video windows writed text ~offline.... In my adroid master profile is the same, but grant access profile everything works fineand shows today's records..... In Master profile I have available. all old records... When I Discovering my Base station all the lights are green... I don't want to write much, because the possible problem is known from the semi-word, and can be prevented quickly.
Are you saying you removed your base station from the settings or did you remove you camera from settings?
