  • 2118 Views
TLDogg
Armed rule only shows 2 of my 3 cameras. How do I add the 3rd?
go to MODE, edit ARMED, pick settings for camera, add camera...SAVE
TLDogg
Thanks but it did not work.  There are only 2 cameras showing in the "armed" setting so only 2 cameras to edit.
I had to create a new rule including all three cameras.
Sorry , you are right... the cameras are added by default ( by prgm ) when you add them as new and you can't add one to the default Armed mode....
If you need it there, you would have to use Remove Device in settings for that camera, reboot the base and then bring that camera back as new...if SHOULD then be in the default ARMED mode.
Or do what you did by adding a new mode and bringing all in to it
