I have an old VMB3010 base that I am trying to use again after being in storage for several years. I am able to connect it using both the Android Arlo app and with my.arlo.com through a browser. Using either method I appear to initially get a successful connection. The my.arlo.com connection process even searches for firmware update and says I am up to date. But regardless of which method I use to connect the base immediately appears as offline in the device listing no matter what I do. I have factory reset the device twice now to no avail. Is the VMB3010 simply no longer supported?
No base station is in the EOL state.
It looks like you have old firmware on your base station and will require an intervention by Arlo staff to push new firmware onto it.
Hello Edinburgh_lad1, I did open a support call based on your reply. Their response was "Thank you for waiting, Bruce. Upon checking here on our system, your base station is no longer supported and reached its end-of-life lifecycle. Our system can no longer run diagnostic tests or pull logs for it." So apparently there are some base stations at EOL and mine is unfortunately among them. Ah well. Thanks for the reply!
@JamesC , @ShayneS , @BrookeN is there any truth in this? AFAIK, @Edinburgh_lad1 is correct, that no base is EOL.
Well, having looked at the official Arlo documentation, I can see that it's only cameras that are EOL, unless there have been further changes that I'm not aware of. Plus, there are also geographical exceptions anyways.
True.
But it is also the case that all the cameras that are compatible with the VMB3xxx bases are end-of-life (outside of Europe). So even though the base is not officially EoL, it might as well be.
I appreciate the information and traffic that has been generated here. Many years ago I purchased this base and 3 VMC3030 cameras as a set. I took advantage of the limited free online storage that was offered at the time which was more than sufficient for my needs. It's disappointing that this equipment can no longer be used at all and may as well be scrapped in spite of being in good physical condition. But it is at least good to have some assurance that this is the case and I thank everyone for their help.
FWIW, it's also possible that the base has just failed.
One option is to do a risk-buy of a replacement, and see if that installs. The best option would be a new VMB4540, since used bases sometimes haven't been removed from the original account (and therefore can't be installed). Of course that is the most expensive path (about $100 US).
You can find used VMB4500 bases for much less - I'm seeing ~$35 on ebay.
Or you can think about our beautiful planet, the impact of e-waste on it (if you're from Europe, then you'll have heard a lot about it from the European Commission and their initiatives to reduce e-waste), and also the money you spent on the system at the time, as well as what was offered (free storage vs. subscription if you but newer cameras), and ask Arlo staff on here to push a firmware update to both the base station and the cameras. Your product doesn't have an expiry date.
Also, if the base station hasn't been used, then the strong likelihood is that it's not failed. Electrical equipment can fail indeed, but at the time, Arlo made quality items that were built to last and sustain a lot. Also, I find that electrical equipment doesn't fail in general as often as one might think (or otherwise hope) it would.
The choice is yours.
Per the first post, it has been used, but some (unknown) number of years ago.
They can only do that if the base is on-line. And per the posts above, the base is not.
That said, it is worth tagging the mods - @BrookeN , @ShayneS , @JamesC - as they might have some suggestions.
I do not have any further suggestions. There is no updates that we can push for the VMB3010.
Once again I appreciate the responses here. I probably will not invest further in the Arlo product line as the responses I've gotten from official support have not set comfortably with me. Even though there is no solution in my case - either hardware has failed or Arlo has cut mine off - I am still curious as to whether any VMB3010's are still in use at all, or if perhaps only those above a certain firmware revision are allowed online with Arlo (thus enabling a catch 22 situation in which the units can't be updated because they can't be brought online).
At any rate, like @Edinburgh_lad1 , I am aware of the impact of e-waste and will be dropping my VMB3010 at an electronic recycling facility in the US. Thank you all for your insights!
There is users that still are using the VMB3010. They have been online and able to get the updates as they have came. With your basestation being offline for so long it has not been able to receive the updates. This particular basestation came out in 2014, it was one of the first basestation that Arlo had.
Thank you @BrookeN . Is there no way for the firmware to be updated even if sent back to Arlo?
@VirtualBruce there is not I apologize, I am sure that is frustrating.
Just in case anyone else finds themselves in this predicament, I thought I would update here.
I did have a phone discussion with Arlo support who in turn handed me over to sales. They were oddly willing to give me a significant discount on new cameras but not on a new base. Unfortunately the solution they offered cost significantly more than I was willing to spend to get the same functionality that I had before. And even if I just decided to buy just a new base alone, no one seemed to know if I could use my old cameras. So, no thank you.
I think there are companies out there that better serve their customers than Arlo and are perhaps less haphazard about supporting the older hardware that's floating around. I understand that there are products that reach "end of life" but it's one thing to say that these products will no longer be supported and quite another to disallow their use altogether. And it's galling that there is no official record online stating that the VMB3010 up to a certain firmware release is truly "end of life". And it's more galling that apparently there are people out there who are still allowed to use this hardware simply because, unlike me, they never left it offline for too long.
I appreciate the help and insight I've gotten here but I'm left with a sour taste and the feeling I can do better elsewhere. Thanks all!
