VMB3000 Cant access internet
  • 5 Replies
  • 1175 Views
Marie13
Connected to router by ethernet cable. Internet light never comes on at all. Removed device but cant "add device" as no internet on base server.
Have confirmed ethernet cable is working.
Done all the power off and back on routines.
Held reset button for 10 + seconds... no activity on that one ....
The only active light is the power light.
NO idea what else to try . Help please...
Had for several years with no problem. Have had turned off for past months as it interfers with internet TV
5 REPLIES 5
Dannybear
Did you try power cycling the local router modem then the base station?
Marie13
Yes I did try that . No change.
Still no connection to internet on Netgear... but works perfectly everywhere else. Only power light lit.
Most likely a failed base station then. If so, you'll need to replace it.  The VMB3000 is no longer manufactured - but any Arlo base or smarthub will work.
Note Arlo hasn't been part of Netgear since 2018.
Dannybear
The missing internet led indicator suggests that the connection between the base and router is missing.
Cable faulty, wrong port used on the router, check with the isp provider for any recent changes.
Easy check is to take the base to a friends house and plug in to their router.
Marie13
I did this and it worked !!! So my internet provider worked to get the router working with hub.. Finally all good. All cameras now added back and system functional again. THANK YOU !!!!
I was going to throw out and just buy a new system !
