  • 6 Replies
  • 650 Views
  • 5 In Conversation
Baggyjim
I have several VMA4600 solar panels connected to arlo pro and arlo pro2 cameras. One of the cables between the solar panel and the camera has failed due to being damaged. Is it possible to purchase a replacement cable or an equivalent ?
6 REPLIES 6
Arlo has no current products that support the legacy cameras. You may be able to find a 3rd party panel but no guarantees. Also, you may be able to repair the cable yourself but there are no replacement items other than a whole panel.
Just want to clarify that @jguerdat is talking about accessories (not the smarthubs).
There are a couple of third-party options that claim to be compatible.  I haven't used them, so I have no idea how well they work.
Scholdis
I have the same issue with damaged charging cable between 2 of my Arlo Go (ver 1) and the solar charger (VMA4600). The cable is with micro usb and rubber sealing, so it would be ideal to find a replacement as the solar charger still works fine. Was it even possible to direct such a request to Arlo Support?
ShayneS
@Scholdis
If this was purchased within the last 12 months we might be able to get a replacement for you. Arlo currently does not have replacement parts.
Scholdis
Many thx for reply. This item is obviously older than one year as the product is discontinued (but the solar panel works so a bit unfortunate). Kind regards /Andreas
@Scholdis you could try wiping the damaged area with silicone rubber/RTV to seal it up. There's also waterproof tape that may be useful to do the same thing. Just be carefully to not pull on anything that may cause the wires to become detached.
