Using mobile data Arlo Pro
  • 2 Replies
  • 2544 Views
Arloharlo
I’m in desperate need to work out how I can connect the Arlo pro base station with a Samsung device (usb c).
I intend to use the Samsungs mobile data so I can view the cameras remotely,
any help would be greatly appreciated.
DannyBearAgain
The arlo base stations require connecting to the internet via an Ethernet cable/port.
This is usually to a network router/modem device feed with the internet.
I am not savvy with Samsung but expect it is not possible using the USB c port on any phone.
The only way might be possible is to setup a wifi hotspot with the phone and get a wifi extender that supports an Ethernet port to connect the base to.
DannyBearAgain
Arloharlo
You was absolutely correct.
i purchased a usb c - Ethernet adaptor.
enabled usb tethering on the Samsung device and connected the cables.
I can now remotely view the camera with ease and I get notifications when there activity.
many thanks for your help
