Using VMB4000 Base Station & VMC4030 Cameras (3) Schedule no longer works.
  • 2 Replies
  • 1188 Views
PhilSmith
Schedule no longer works properly on my system.  I have it set to Alarm at 12:01AM and Disarm at 6:00AM.  While that setting worked well for several years, the system won't Disarm at the selected time.  Currently, I have to Disarm the system manually every morning.  I then select Schedule and the system Arms at the appropriate time.  I've tried deleting and re-creating the Schedule several time, but that doesn't fix the problem.  Would welcome any suggestions.  Thanks!
First thing to try is a power reboot of the base....
It may in the end require a full reset of the base which rebuilds all the data kept inside
PhilSmith
Thanks...  The power off/on reboot fixed the problem.  Thankfully, I didn't have to do a complete system rebuild.
