Using Arlo Pro in Australia
  • 1 Reply
  • 3828 Views
Retired_Member
Not applicable
Hello,
I was wondering what i would have to do to use a Arlo Pro System imported from the United States for use in Australia. I know it will require an adaptor for the base station but what about the batteries in the camera itself? and also anything else i may need to know regarding the use of this product.
Thank You
Streak2
Master Master
The base adapter is 110v only. You should be able to find another power supply there with the same output specs.
The charger power supply is universal you'll just need a US to Australia. 2 pin adapter.
Batteries are rechargeable by the charger mentioned above, no problem there.
The rest should work fine. Waiting to see who'll be the first guinea pig there.
