Can someone tell me what steps I need to take to replace my old base with a Arlo Pro base? Do I need to "Remove Devices" or "Add Decice" then start from scratch with the new Base?
Almost. You need to remove the cameras, too and then start fresh by adding the base and then syncing the cameras.
