Unable to connect to home kit
Thank you
This did not work. When you hit the home kit icon. The discovery window opens but when it says devices found the wheel keeps spinning. Nothing loads.
Can you try removing and reinstalling the Arlo Secure app.
Hi unfortunately this also did not work. I even tried rebooting the base station after uninstalling and reinstalling the Arlo secure app. What should I do next to resolve my issue? Thank you for all your help.
I will continue to investigate this for you, but in the meantime you can try rebooting and re-installing the app again. This has resolved the issue in the past. Make sure you have the latest version 3.6.8 You can also try via a different iOS device as well.
