USB Storage
Hi All
I am trying to setup USB storage on my base station.
I read the instructions and put a usb stick in the slot but when I go into my device there is no where to setupthe storage.
Step 5 says "Tap or click Local Storage." but it is not there.
Can anyone please help with this?
thanks
PS: I was told I had to add a label to this post but I only had three to choose from.
If you are using the original Arlo base ( skinney flat front tilted back ) it will NOT work.
The USB backup is only supported on the newer Pro or Pro2 base unit.
The usb ports in the original base unit are nonfunctional and were placed for future options but never actually completed till the newer base units came out
