Trying to connect motions on Arlo Pro to alarm/siren. Not seeing this option.
  • 1 Reply
  • 1111 Views
NorthHike
I am trying to connect the motions on our Arlo Pro camers to the alarm/siren (i.e. when motion is detected the alarm goes off).  It looks like from what I read that you go into "Mode" and select the camera and edit to get this to work.  Well...the only options I have are that when motion is detected I can select "Record" or "Do Nothing"....I don't see a placeto trigger the alram except to do it manually.  Very confused and searched all the menus in the app and all I can see if how to activate the alram.   Help!
When editing the rule, use Add Device to select the alarm.
