I just brought the arlo pro system. I have connected the base and I can sound the siren on the base. However when trying to sync the cameras the blue light blinks for about 30 seconds and then blinks orange a few times. Cameras do not connect. What may I be doing wrong
Pul the battery pack for a few secs , replace... this resets the camera
Attempt another sync but do NOT hold the base sync button, use only a quick push and then the camera a sec or two later..
( this is the most common error, btw, of holding the sync button to long )
