Hi , so my time zone is set to Ciaro , gmt+2 , this is the correct time zone . However they have daylight savings and we do not . So in their summer the time is 1hour ahead . It automatically selects Ciaro , is their anyway I can change this ?
See if you are able to change the time zone following these steps:
https://kb.arlo.com/000063101
When I enter my address it automatically selects Cairo as I time zone and I can not change that on the Android app
Can you select the right time zone if you remove your address? (you can just leave it blank).
