The Arlo device is offline
I just received Arlo Pro kit with base station and 4 cams, connected a base station, all the lights are green.The wifi signal is perfect. The network in my house is working fine.
The cameras connected first, updated firmware, but then all became offline.
I tried to restart the base station, reconnect devices with/without unplugging battery - doesn't work.
P.S. I connected my base station to ethernet socket, not to router directly. Is it ok?
My first feelings are the deepest dissapointment. 😞
Define "connected my base station to ethernet socket, not to router directly" - what socket? Is it connected to your network? Is the Internet LED on the base still green?
Sometimes things like this happen. The quick thing to try if the base is showing all green LEDs is to reset the system by removing all devices in Settings, My Devices. Use the Add Device button on the Devices tab to add the base and sync the cameras. Is it working now?
It was connected to ethernet port in the central room, since ethernet hub and wifi-router are located in the other room.
Should i connect it directly to hub or wifi-router?
Open a case with support using the Contact Support link at the bottom here.
