Hi All. I have several Arlo pro cameras but unfortunetely, Arlo plans are not available in my country and am not able to add all my cameras under same account
Is there a way to get the subscription and add all cameras in my account
Let me know pls
1. Use multiple email addresses to create multiple accounts. Each account will need at least one base. You can then use Settings, Grant Access from each additional account to the original so you see all cameras in one account.
2. Remove all devices from Settings, My Devices and move the system to a country that has the additional plans available. Set the system up in this country and upgrade the plan using a credit card from the same country.
When is there going to be more choices on plans. I am fine with almost no storage time for recordeings, maybe a couple days but I want to have 10 cameras on. The cheapest plan that will work with 10 cameras is $100 and stores video for a month. I dont need a month, can there be a plan for people with up to 10 cameras and store the video for a couple days and charge much less. I honeslty feel with the cost per year and the price of your cameras/router there are many other choices. I can get a D-Link system for less and store the video strait to my PC and keep it forever for free. I pruchased 2 D-Link cameras to simply check it out, kinda cool they both rotate side to side and up/down, they have speakers and a mic for sound, both HD. They work very well and no monthly/yearly plan needed, granted they are not weatherproof but nice. My plan is ending in a couple days and Im not sure I want to stay. I see that there was a "coupon code" box next to where you re-new your plan but I have never been sent any kind of offer to stay. I would think as a returing customer you would offer somthing. Anyway hate to rant and I am not sure if this is the right place to escalate this but it was the only chat that I could find that was kind of close to being related to a plan.
RamTruckGuy,
At this time, the Premier Subscription plan is the minimum plan for up to 10 cameras. If you do not need the extra storage and you have a second base station, some users have found it helpful to set up two separate accounts and then utilize the Grant Access feature to share cameras from the second account to the first.
