Striped interference on the screen after LED install
  • 4 Replies
  • 2612 Views
Davzav
Hi
I installed a LED lighting room and since then I have a striped interference on the screen
Interference from the LED?
Is it on the same circuit?
does it go away if the led if off?
I use LED lighting in various rooms with no interference. If you turn the lights off and maybe use different lighting does the problem go away? If you move the camera to another location is it ok?
Davzav
If you turn off the light in the room it disappears.
It is important to note that in the past there was a LED lighting room and there was no problem.
The filter in the LED circuit is probably not working properly
Post a screenshot of the problem for us to see.
