Page 56 of the manual shows how to turn off the status light.
I do not see the status light to tap as shown in #4 below. What am I missing here? Thanks.
3. Tap or click the camera. The camera settings display.
4. Tap or click Status Light. If you are using a mobile device, your settings are saved
Huh. Guess it got removed. New firmware automatically turns it off?
yellowsubmarine,
Are you referring to the LED for fully charged battery? This can be turned off under settings and is labeled "Battery Fully Charged Indicator".
No, the notification LED. At least I believe it used to be there like the Q cameras. Am I remembering wrong?
