  • 1336 Views
Fireguy1451
I just mounted the solar panel charger and hooked to my camera. with in a few minutes I started to get a electrical smell and got concerned. I quickly unhooked the charger and removed the battery. is this smell something normal and will go away? Am I doing something wrong? Do I remove the batter from the camera and the charger have buil
It seems unlikely to be the charger itself.  It produces very little power.
Do you get the same smell with just the camera (battery inserted)?  If not, do you get it when you use the normal AC power adapter?
Fireguy1451
so after some research I some how missed install a full battery first so I did that and reconnected and no smell, must have been a big draw charging as the previous battery was almost dead. been 2 days now and its been overcast but the battery staying full.
Wouldn'ta thunk it would be a high current draw since the panel can't supply much current. ANythinng is possible, though, so it's good that things are working for you.
