Siren would not disable via phone after turning it on to test
wow talk about a pain in the ass. I just upgraded to the pro and i turned siren on just to test it and it went off and would NOT disable from arlo android app. I had to go and unplug it.. Because of this i probably wont even use this feature. has this happened to anyone else?
Did you try the button on top of the base station that turns the siren off?
First time I tested it out I didn't get the "turn off" red button. Second time worked fine though, maunually triggered or through a rule
