Setting up custom modes
I feel so stupid, I have 4 cameras and want 1 of them to be 24/7 front porch however the other 3 i am ok 10PM to 7AM i tried to add a custom mode but cant figure out how to separate 1 camera from the other. Is it me is is ARLO not so user friendly?
Help please I am exhausted, how can this be so hard?
Go to ADD a MODE ( in modes )
You need to make a new mode to split out the Front porch cam and the others
( remember , any cam NOT in a running mode is off , only one mode can run at a time )
So make a mode for cam B/C/D ( others )
Add a mode for B, setup and save
Now go back and edit the mode to add C , save then repeat for D
For times when all are on just use ARMED, for times when only the other 3 are on use the mode you just made
** if using schedule , you can't go thru midnight so when you try and set it up...go 10pm to 1159pm and then next dayday start at 12 midnight to 7am **
