  • 5 Replies
  • 2083 Views
sawhorse30
Setting up a new Arlo Pro base station and I'm not given the option of local storage so I can't recoed to a USB device.
Suggestions please.
5 REPLIES 5
The Pro base allows a backup record to the usb port ...via a hd or speedstick ( easier  to do )
You don't mention what format your stting it up on , if at all possible, setup on a PC
sawhorse30
I'm using an external hard drive formated to exFAT.  Base station USB light does not come on and in Settings, My Devices and selecting the base station t here is no option for local storage.
Also formatted a USB stick to FAT32. The base station USB light does come on but no option in settings for local storage.
jrh1194
You indicated that you have the VMB300 base. I could be wrong, but I don’t believe that the VMB3000 base has the usb backup capability. You may want to check and verify this.
Yes the Arlo/ 3000 does not have the USB port active and there is no option for a drive there.... But the newer Pro that he mentioned does.
btw it must be formatted in Fat32
jrh1194
He mentioned the Pro, but his post states that he had a VMB3000 base.
