  • 5832 Views
melpluschris
Hi there,
I have just setup/installed a Arlo Pro system with 4 Cameras.
I want to use the "Geofencing" mode so the system can activate/deactive automatically which seems simple enough.
I have set the AWAY MODE to "Armed".
I want to set the HOME MODE "Disarm",
but want to setup so that 3 exterior cameras come on at a set time in the evening (Say 10pm) and off at a set time in the morning (Say 5am).
The interior Camera can stay disabled duing "Home Mode"
What is the easiest way to achieve this?
Chris
Use the schedule to turn cameras on and off as desired. You may need to create your own custom modes to accomplish this.  Then use the schedule for Home.
melpluschris
Doing this can I still use the geofencing mode and just add a custom made mode for home mode? And how do I setup individual schedules for cameras?
Check out the FAQs here for creating modes and rules. If you need different rules for different times, create more modes. Each mode can hold different cameras and settings which can be scheduled at different times.
