Serial Number: 4R05917NAEA2C
Will not sync to my iPhone 14. Says that it does not trust the device. Try again...this is getting to be quite frustrating!
Some users have reported success by simply uninstalling and reinstalling the Arlo Secure mobile app. For others, following the steps here were successfully: https://community.arlo.com/t5/Arlo/Add-trusted-device-on-new-iPhone-Issue-Resolved-Workaround/m-p/18...
This same issue was open and closed on an older link. It says "resolved" but it has not been fixed. I just bought a new iPhone 14. I'm getting to the screen of "trust" or "don't trust" the device. If you push trust it fails. I chose "don't trust" and it works??? Still an Arlo problem
andyp3,
Have you tried the workaround posted above?
No, because the don't trust option worked.
