I plan on setting up two cameras (to start), one in the living room, and one outside above my front door.
Is like to have the front door camera motion activated at all times (even when I'm home), and the one in the living room to act as a monitor (disable motion sensor) since I have animals that would trigger the motion sensor throughout the day.
Are these settings possible?
Yes. Go to the Mode tab, click on your base and create custom modes that have only the desired cameras in them. To add cameras to a new mode, reedit it. Then place the appropriate mode in the proper time slot in the schedule.
As mentioned Yes... you must split up the cameras to 2 new custom modes , ie: Inside and Outside so you can arm each one on it's on.
Thank you!
I'll try these settings this weekend.
